I'm installing new emergency lighting in my 2020 Ram Bighorn and would like to know what's the best fuse to use ? I have fuse taps and need 2 - 12VDC sources.
Hi Mardem I have a 2020 Ram 1500 Laramie crew cab and I just installed LED lights for my running boards. What I did was tap into my driver side floor flood light - These lights come on whenever you unlock your car door or open any door along with your dome light. It is located just under the dash near the edge by the OBD plug. There are actually two lights one is for the footwell flood light and the other one is for the ambient lighting which will illuminate during night time hours and are dimmable by your ambient adjust switch. The light plug has three wires on it a Black wire, Yellow wire w/purple stripe, and a Yellow wire w/green stripe. The Yellow wire w/purple stripe is for the footwell and dome light connection. The Yellow wire w/green stripe goes to the ambient lighting circuit. and the black wire is the Negative (ground) wire. I connected my driver side and passenger side LED lights together and connected them up in parallel so both running boards light up at the same time. The plug was easy to remove to access the wiring to tap into. But if you really want to tap into a fuse block I would use the one under the hood and it would be much easier to access than the one under the dash in my opinion. I hope this helps and good luck.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
