Same. I'm guessing a 34" equivalent with no problems.following ....
You’ll be able to get a 34 on there (AND in the spare tire area). If you want to do the minor fender trim on the rear of the front wheel well, you should be able to go 35. Unless you’ve worn out the factory tires, I don’t think the 1” gain would be worth the dollars and hassle. With 35, you’ll either have an undersized spare or a full-size mounted in the bed/somewhere else.
