On my 21 the left side cable is slack putting all tension on the right side. Found this, that gives part # for replacement correction. This Bulletin was for 19-20 models, but apparently is spilling over into 21's. If it's just holding the weight of the gate then no problem, but in my case I'll be putting heavy things up there and want both sides to equally carry the load.
