TDHawks
- Oct 3, 2022
First off, will that setup work?
I originally swapped out the factory rubber for some 305/45r22's and I do like them, no issues. However, I want a more rugged look with more rubber. I have the Eibach leveling shocks on the front and I believe it's set at 1.8" so the truck should be flush.
If I were to move to a 18" or 20' wheel with a - offset, would I be able to run these with minimal to no trimming?
Thank you.
Thank you.
