dts828
Expensive, doesn't the front differential need to be changed also.
The EPA rating is tested on a 3.21 rear end. 3.92 is an at-cost option and thus not required to be in the EPA rating testing. Frankly 3.21 and 3.92 costs FCA the same, and 3.92 is an at-cost option for the purpose of getting a better EPA rating. Fun fact, the reason auto start stop is on by default every time you start the car is also due to EPA rating. EPA requires standard feature that most users prefer to be tested, that is if manufacturer has reason to believe auto start stop feature will be permanently disabled by a large amount of users if allowed, they'll have to test it with the auto start stop disabled as well.I think you have me confused with someone else as I am not arguing against you or posted any logic.
What I will post is two window stickers that don't seem to suggest you get 4-5 more MPG with 3.21 rear end.
I wanted to get 3.55 and live in two worlds at the same time but a paper pusher somewhere decided that option isn't available for Hemi's
Crazy idea, but work with me.... bigger tires will effectively change the gears. You just need like a 38 or 40 inch tire, oh and a 6 or 8 inch liftHow realistic / costly is it to switch a truck that comes with the 3.92 gear ratio back to a 3.21?
I’ve found several trucks that I like that have the 3.92 instead of 3.21, but I do not need the 3.92 as I do not do a lot of towing.
I realize this may be a really stupid question.
