Swapping Interior To Gain Heated & Vented Seats
Phi1Wh0
Florida
I have looked through the forums and cannot seem to find an answer on this. I have an opportunity to acquire a mint Laramie interior with heated and vented seats that I want to put into my Lone Star. I already have the 12" screen from a Laramie that had the same interior I want. Since the module is already situated to control the upgraded interior, is there anything I need to do with the computer once I put the seats in for them to be recognized and work properly? Or will this (hopefully) be a plug and play swap where the system will recognize the seats and they will operate correctly immediately upon installation?
Thank you all in advance!!!
vincentw56
You will need to use AlfaODB to enabled the functionality.
Phi1Wh0
Florida
Is that the only thing. Will the seats be direct installs between the two, or well I need to chase wiring?
Cajun_
Louisiana
I've been wondering how to add ventilation to my rear seats. I wonder if I need new seats or just an alphaobd and the fans and buttons
Snofire
WI
You would need new seat pads as they are different than seats without. Otherwise you won't get any airflow from the ventilation fan. They installed the wrong foam in my driver seatback and had to replace everything.
