Superchips tuner now available
banditsc
Interesting that the non etorque gets higher HP gains and the etorque gets higher torque gains. They do require a PCM swap though..
$250-$720 depending on FlashCal, FlashPaq, or Dashpaq
But do they really add hp??
I believe DiabloSport found the same thing.
I would assume this actually disables MDS so that’s nice. As for the power, typically they just get more aggressive in the midrange areas. You can’t really add peak power to something like this, not enough to care about. I would imagine it probably feels pretty sporty compared to the stock tune, especially in 1/2 throttle areas but if you are looking at this to “go fast”... waste of time. I would also recommend only running 93 with any of these.
I've had superchips is many vehicles and typically it feels more in the midrange area and moving shift points to match torque curve gives you better feel also.
