Cmerkert
I have to draining my battery to the point where my 2019 1500 would not start I recharge it and it took several hours for the systems to return such as stability track control and the transmission shifting out of first gear when driving. I had read that that is common for it to take several hours for things to return. Everything is return to normal except for the sunroof Systems in shade. Pressing all three buttons do not cause anything to happen and the fourth button on the roof which controls the rear window does work. Does anyone know if this is a common problem if it takes more than 24 hours or if there is a fuse issue? Has anyone else Notice the same situation where the sunroom does not return after a dead battery
