Stuttering under slight acceleration?
Smerberj
Virginia Beach
So I've noticed on a few occasions while gently on the throttle to gain speed on the highway my truck seems to "sputter", if you will, but if I give it more gas it stops. It's almost as if it doesn't know which gear to go into on the slight acceleration but once I punch it, it makes up its mind. Anyone else have these issues? Seems to only happen from 50 - 65ish mph.
It could be the displacement on demand if the cylinder reduction is active. Generally if you give it more throttle, it kicks in the other cylinders, but it does feel as if its stumbling a bit if youre using light throttle.
Hi @Smerberj - If you decide to address this with your dealer at any point, please do not hesitate to follow up with us via PM for an additional layer of support through that process.
Mark
RamCares
What happens when you engage manual shift mode while experiencing this "sputtering"?
Does the sensation go away?
Steve
I'll check next time I experience it. My truck didn't do it at all today.
"Stuttering"?...gee, my Limited doesn't talk at all...
