IvoryHemi
- Jan 3, 2021
Isn't one of the advantages of the eTorque system is that it adds low-end torque? I can't be sure, but I seem to recall reading that somewhere. If that's true, then the torque added to the engine by the eTorque system could what helps the engine stay in ECO at lower speeds.
Just my $0.02 (before tax). YMMV.
Max output is 130 lb-ft off idle. It’s output drops off as engine RPM increases. BSG spins approx 2.5 times per crankshaft rotation to get there. Basically the engine output becomes greater than the electric assist. I recall reading over ~1500 rpm output is zero
So below that you’ll get a boost, over ~1,500 rpm is all Hemi
Which is why most people can’t feel a difference because it’s operating range is so small
