Stereo Harness 2019-UP DODGE RAM 4-CHANNEL AMPLIFIER HARNESS W/ CONVERTER WITH ANC
Ram_John
Hi everyone I know alot of posts about upgrading stereo system. I want to know if anyone has used the above harness from netaudio and how it worked out for them.
I have 19 Ram Big Horn with base 6 speaker system with Active Noise Control ANC. I want to use this harness to run amplifier for door speakers and maintain fade and balance control but do not want to pull head unit and run t harness with the PAC Amp PRO AP4-CH41. Harness from netaudio is not much cheaper it is just a more convenient point to run amp to the back. Thank you in advance
John​
Wire4money
I used a cheap ANC bypass harness off Amazon cut in half, hooked up to a Kicker Key 200.4 mounted on the bracket the ANC was mounted to.
