Steering wheel vibrate at 45 ~48 mph
liq001
Hello all,
I had a 2022 ram 1500 limited truck. I have put 27000miles on it with original 22 wheels. Recently I noticed a vibratation at speed 45 ~48 mph and get much better at higher speed. It not happen at acceleration but happens while decreasing to that speed range with out any braking. No vibration at all while braking. Any ideas what’s going on? Thanks? Tire wheel balancing needed maybe?
cerbo
TN
if you feel it in the steering I would rotate the front wheels to the rear and see if it changes. if it does then it was a balance out. simple and free to check a likely issue first.
