Start Stop System Issue, Only during cold starts & P0456
Jerryallday
New to the Forum, I have a 2019 Ram Rebel 3.6 v6. 78K miles
I have been having issues with my start-stop system. I took it to the dealer and they told me to replace my main battery and that would fix the issue.
Well, it hasn't after replacing the main battery. One thing I have noticed is the light only comes on in the morning or after the truck has been sitting overnight. If I drive a few minutes and turn the truck off and back on right away the light disappears. On my way home from work, the light doesn't come on either. It only when the truck sits for at least 10-12 hours. Do I have a small battery draw?
The truck has been giving me issues and it feels like they all came at once after years of no problems. at the same time, I had a CEL with a missed fire in cylinder #4 and found coolant in the cylinder. I had both sides of the heads resurfaced and new gaskets everywhere they were disturbed, new spark plugs, coolant, and oil. This fixed that CEL light.
Yeterday, I got a P0456 CEL. I did a little research and ordered some parts from Rockauto based on some videos on YouTube. Parts come in tomorrow, I reset the CEL light for now and it hasn't returned.
2019 RAM 1500 3.6L V6
DORMAN​
310219 (310-219)Vapor Leak Detection Pump
$ 15.18​
$ 0.00​
1​
$ 15.18​
DORMAN​
911410 (911-410)Vapor Canister Purge Valve / Solenoid
$ 17.75​
$ 0.00​
1​
$ 17.75​
6of36
Michigan
DORMAN​
$ 15.18​
$ 0.00​
1​
$ 15.18​
DORMAN​
$ 17.75​
$ 0.00​
1​
$ 17.75​
You started a thread about start stop issue, and you told about other issues, but didn't really explain what your issue is with start stop.
23RAM
Canada
You have a 4th generation RAM so you're asking in the wrong forum. However, it sounds like a heat-related intermittent problem.
Alakdan
DORMAN​
$ 15.18​
$ 0.00​
1​
$ 15.18​
DORMAN​
$ 17.75​
$ 0.00​
1​
$ 17.75​
How did you replace the Vapor Leak Detection. Seems it's PITA to replace due to heatshield blocking.
Cbty2050
You used YouTube to order parts, imagine if there was a video source on how to replace the ESIM.
Alakdan
I got the part number using the VIN in mopar store and cross ref it for local available non mopar stocks. Hope I got the right one.
I'm gonna try again today to replace the ESIM by bending the heatshield.
Triton2k3
Did this resolve your problem? I am having a similar issue.
Alakdan
2 months ignoring this error. Clearing the code everytime it show up.
I just replaced it today.
The permanent error code P0440 is gone now.
