- Jun 8, 2021
- Solutions
- 1
My Rebels had two-tone, and it didn't show up on the window sticker either.same... said it cryptically on my BS and not on the WS.
Dang, I got y'all both beat! With a truck that definitely wasn't made for towing!
Yes, or thereabouts. The truck doesn't officially show up in their system until it's built.So can you only do this if you have a BS?
My ESD has already been pushed twice. I was expecting it considering the issues that the plant has been having. At least the blockade is over with. Let's hope the supply issue has been resolved.Thank you!
I actually just heard from my dealer. ESD was today and has now pushed to 2/18.
| Series | Qty |
| Longhorn | 27 |
| Laramie | 38 |
| Rebel | 87 |
| Limited | 154 |
| TRX | 282 |
I guess those TRX’s had tire carriers, Rambars, and the big-*** trailer mirrors, huh?Of all trucks built to date
Current Max Tow is 11990lb (Payload of 1890) On a Bighorn and they have built
Current Max Payload is 2320 (Towing of 8120) On a V6 Tradesman
Minimums are
Tow: 6192
Payload: 928 ???
There are currently 588 trucks with payload of less than 1000 lbs. They all seat 5, but we will say 4 comfortably. You put 4 grown men in the truck and you are at capacity forget anything in the bed or even on a trailer because you have no tongue weight left??
Series Qty Longhorn 27Laramie 38Rebel 87Limited 154TRX 282
That would be exceptionally
Dealership (MD) just emailed me that I hit the jackpot and my truck is scheduled to build 2/20. That’s 10 days after ordering….crazy! I feel for those that have been waiting a long long time though, something’s not right with that.That would be exceptionally quick.
Weight is like age. It's just a number!!Of all trucks built to date
Minimums are
Tow: 6192
Payload: 928 ???
Until you have an accident and it’s determined you were over loaded. Then the bill they hit you with is just a MUCH LARGER number.Weight is like age. It's just a number!!
Interesting. I have a 2022 limited 4x2 with the 5’7” box and mine lists a max payload of 1321 Lbs. That is a significant different over a 6’4” box. I’ll never come close to the max payload though.Payload look up works now. Half ton like a boss!
Yeah there are a couple of threads on here that discuss payload and towing. They are excellent resources for anyone looking at buying a RAM with the intent to use it as an actual truck.First time orderer. When I started researching/building my Laramie, I went off the following information
I looked up my VIN and almost cried. I had NO IDEA adding options would drop my payload so low???
I have the following options:
5.7L V8 HEMI MDS VVT eTorque Engine
8-Spd Auto 8HP75 Trans
33 Gallon Fuel Tank
3.92 Rear Axle Ratio
Laramie Level 2 Equipment Group
Off Road Group
Night Edition
Bed Utility Group
No idea what options I added to drop the Payload so much. It should be delivered any day now and I'm not sure if I want it anymore. I'm disgusted right now....
it's those damn front seat back map pockets.First time orderer. When I started researching/building my Laramie, I went off the following information
33 Gallon Fuel Tank
Off Road Group
Night Edition
Bed Utility Group
Maybe take out the foam bottle inserts as wellit's those damn front seat back map pockets.
