Ramontario21
- Aug 10, 2021
Any build sheets this morning???Added 1235 Window Stickers tonight. No members.
Push your dealer. I had a dual pane sunroof added after my vin was produced. Sounds like the dealer doesn’t want to do the legwork for youReached out to my dealer about seeing if I could switch from Rebel Level B to Level 2 and being told I was not able to switch due to a VIN being produced already.
No. Production was closed for ThanksgivingAny build sheets this morning???
For sure, All VINS are tracked regardless of forum member status.imo the vin should still be tracked just in case it is not canceled.
maybe, maybe not, only ram knows for sure and they ain't talkingSo I tried to order a Back Country with level 2 package, delmonico red, 9 speaker amp, 8.4 nav, and as we were optioning it out the premium lighting group and blind spot were not available, grayed out. Is this due to the chip shortage?
Were you able to get Level 2? I have one on order (Back Country) and Level 2 was not available at my time of order (early Oct) and I have Level B.Well that sucks. I might have to go with the Laramie instead. Led lights are a must have.
Thanks for the reply.
FCA system said it was available. I did not place the order though since I want, need, led lights. I'm contemplating going with the Laramie instead.Were you able to get Level 2? I have one on order (Back Country) and Level 2 was not available at my time of order (early Oct) and I have Level B.
Laramie had blind spot grayed out when I checked yesterdayFCA system said it was available. I did not place the order though since I want, need, led lights. I'm contemplating going with the Laramie instead.
Even though blind spot is important I can do without it. LED lights are a must have though.Laramie had blind spot grayed out when I checked yesterday
Limited has both standard.Best deal on a Ram unless you want the G/T packageEven though blind spot is important I can do without it. LED lights are a must have though.
I had a 2021 Limited ecodiesel. Great truck, after a while though I realized that it had too many expensive features that I did not use. I also missed the roar of a v8, mpg be damned.Limited has both standard.Best deal on a Ram unless you want the G/T package
