Squeaking from the rear driver’s side
Get you a can of wd40 gel lube and hit every bushing you can see. Usually a squeak would be from rubber.
I used a silicone lubricant and sprayed all that i could find, still squeaking. Would the gel lubricant possibly work better? I’ll grab it if so
