Squeaking from the rear driver’s side
hayden536
This squeaking just started happening going over speedbumps. No air ride. Thinking it may be bushings, any ideas are appreciated!
Click to hear squeak
Get you a can of wd40 gel lube and hit every bushing you can see. Usually a squeak would be from rubber.
I used a silicone lubricant and sprayed all that i could find, still squeaking. Would the gel lubricant possibly work better? I’ll grab it if so
You thinkin the mice ate my bushing?
Yep, they chew on lotta stuff. Them thar’ soy bushings are mouse treats!
Mouse, Rat, Mammal, Muroidea, Muridae, Rodent, Hamster, Gerbil, Pest, Skin,
Update: this is caused by the bushing for the Hellwig Rear Sway bar, spraying silicone-based lubricant on it while it was installed did not fix it. I uninstalled it, re-greased it with heavy duty grease and reinstalled and the squeak is 90% gone for now.
