Sport Sticker Removal?
ScottyJ
Has anybody removed the sport sticker off the bed of the truck? I like the looks of the sport version with the painted bumpers but don't care for the sticker on the bed.
Following …. I plan to do this the day I pick it up …. I assumed it was as simple as heating with a hair dryer, catching a corner with a credit card, and peel slowly … Interested to see if there are any helpful tricks …. I assume the paint is fully cured when it hits the dealer, so there shouldn’t be a waiting period
Yep. Easy peasy. I had a heat gun at hand...but didn't need it. I just found an edge with my fingernail, and pulled. I pulled slowly and carefully and it came right off. I washed off the minor residue. I only had them on for a month or two.
I have. Used a heat gun and just gave it a tad bit of heat and pulled it right off. Followed by a quick wipe with denatured alcohol and any left over goo was gone. Took maybe 5 mins if that.
Thanks for the feedback. I figured it should be that easy.
I pulled mine last week with no heat. I'm partial to 3M spray on adhesive remover to clean up the remaining glue.
Don't blame you, cringed when I saw they added that useless decal on the 2020s, looks so bad
As others said, easy to remove especially when they haven't been on there too long. And using a hair dryer rather than a heat gun is a good idea. Almost impossible to damage the paint with a hair dryer but you can get into trouble with a heat gun. But in my case I just peeled up a corner and gently worked it off. I removed all the decals as I'm not a fan of stickers. A little mineral spirits on a rag will take of any glue residue then just wash the area.
