Pull the whole cluster out from the dash and once removed you'll see small plastic clips around the outside edge of the cluster that go all the way around use a small flat head screw driver and pry outward while pulling out wards on the face of it and it will separate fairly easily.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
