Orion10182011
I just got finished upgrading the spks in my 2020 Ram. Here I will post what I learned. I know there is a huge but confusing thread and a lot of my info came from it.
All the factory spks are 2 ohm. The Metra adapters are wired backwards(ones I had anyway). If you look at the back of the factory spk with the connectors at 6 oclock the right side is the positive.(verified by 9v batt test). Take care to get the speaker polarity correct and there won't be any issues with the noise canceling system. Get one backwards and it's a $%^ show.
I used Infinty Reference spks which are 3 ohm. 6x9's fit in the front doors just fine don't believe Crutchfield. There are 3, 3.5 spks in the dash and 6x9's in each door. Front doors are doing bass only, rears are mids. Also 2, 3.5's in the rear headliner which I left stock. I also left the stock Sub woofer. Aparently it has 3, 2 ohm voice coils if what I read is correct.
The results... It's a vast improvement in sound quality. It would be nice to have a better harder hitting sub but with the idiosyncrasy of the of the factory amp and the noise canceling system I'm probably going to leave that alone.
I may have lost a little volume with the 3 ohm spks but I suspect they are higher efficiency than stock so its likely about the same as before.
