Chopperbobby
- Nov 19, 2020
Just shy of 25000 miles and rough starting and idle. Engine light on. Took to dealer and spark plug coil bad. Is this a common problem?
Not common at all.thanks. Just took it back for the third time in a week for the same problem. Dive it home from the dealer fine. remote start the next morning starts then shut off after just a minuet or two. Check engine light comes on and it runs rough.
Dealer first time in updated the computer. said there was a tech bulletin on it.
Second time: got a cylinder 8 miss fire. Replaced spark plugs and coil.
This morning turn on and engine light on again? Starting to get Pissed. The invoice said they switch the coil with another and the code followed it.
This is starting to suck
Some'in fishy is going on with this motorSo cylinder 3 had a bad injector. They fit me in today!!
So recap of my misfire issues. 2019 cylinder 5 had a bad injector, Nov 2021 cylinder 7 had bad compression so they swapped the head, and then yesterday cylinder 3 had a bad injector.
Yea unfortunately they explicitly call out spark plugs as only being covered under the 2 year / 24k miles emissions warranty.Had my 19 in for a cylinder 1 misfire. Needs a new coil and plug. Apparently they are considered a wear part and is not covered under the extended warranty. Only have 45,000 miles. Manual says they are a 100,000 mile part.
It seems they changed both because they couldn’t determine if the coil or the plug were the culprit. But, since the fix everything has ran great. MPGs have gotten better also.Coil AND plug sounds a little fishy. What are the odds of BOTH being bad? Or is the dealer just not able to determine which one, and throwing everything at it?
