2019ramshortbedcrewcabguy
- Dec 31, 2018
This only applies for trucks on air suspension. So I found a very informative video on YouTube:
Learned 2 things:
1.) You can make your own level links with COTS parts. My best guess is, for one link: 1 X https://www.grainger.com/product/BANSBACH-EASYLIFT-Zinc-Plated-Steel-Elbow-Joint-6UDU2, 1 X https://www.grainger.com/product/BANSBACH-EASYLIFT-Zinc-Plated-Steel-Elbow-Joint-6UDU1, 1 X M5 threaded rod of the correct length, 2 X Washers, 2 X lock nuts, you have a link for around $20-$30.
2.) A lot of folks use shorter level sensor links to remove rake. Unfortunately, they can't achieve full level without facing harsh or bouncy ride in OR height setting and/or error messages. This is because the bag becomes a bit overinflated up front which does two things in analogy to traditional spring/shock strut: makes the effective spring rate too high, and makes the effective damping too low. Solution from this video: add a level kit on top of the front air strut so it can achieve level without having to extend the bag as much.
Sounds like a pretty good idea, especially with the kit he used that had polyurethane spacers, alot more compliant than aluminum or steel and probably make the ride even more floaty/numb. I'd really like to try this out. Anyone foresee any issues? Also, does anyone know if it's the same air strut in the Gen 5 as in the Gen 4? I'd really like to use that polyurethane kit but they only make it for the Gen 4s. I'm guessing the strut mounting point is identical for air and non-air (just makes sense from a manufacturing perspective for FCA)?
Learned 2 things:
