HogNot
I purchased my 2019 RAM Laramie in July of 2018. This truck has lived up to the Great Reviews that I have read and has been flawless until mid October when I lost all sound from the Alpine Sound System. When the dealer said it would be many weeks before they could look at it I thought I would try disconnecting the battery to reset it. This worked but for only a few days and when it started acting up again it was cutting In & Out; ON for 2 seconds and OFF for 2 seconds and only did it when it was cold out which is probably why the problem didn't appear until October. Once the cab warms up and the truck was shut off for awhile it would work correctly and continue until the cab got cold for a long period again (overnight usually). Well to make a long story short, its been to the dealer 3 times now. The first time they had it for about 3 hours, the second time, 5 Days and the last time 7 days. The last time they replaced the amplifier and when I picked it up it cut In & Out immediately. Now a few days later, it does it all the time even after it's warm! The dealer is scheduling me with another loaner vehicle and taking it for more test. I have noticed one thing and that is that the sound system works when the ignition is in "ACC" and if I put it in "RUN" mode it cuts In & Out again wither the engine is running or not. During the entire time that I've owned the truck another issue that I've had is that the Station Memory Presets on the SXM Radio don't stay programmed. They may disappear after an hour or may last days. Here is a YouTube link of a video I recorded showing the problem,
. Any suggestions on what I should do next, would be greatly appreciated.
