The 285/60R20s Bridgestone Dueler AT Ascents are running 39psi Front and 35psi rear.
I started at 39 all around, then 38 all around, then 39F/35R and am pretty happy. I've debated trying 40F/36R at some point, but may not "chase" it much further until I swap in the Fox PEs soon.Im still searching for the right psi for these ascents. Had them at 38, then found out about the difference in weight rating between E and P rated tires. So i pumped them up to 52. They run fine but are rough like an e rated tires is expected to be. So i just dropped to 46psi, well see if I can find the sweet spot and just pump em up for towing.
