That’s transmission temp. You can change it in the settings in the IC.Here is a picture, I hope
Its a scale...? Seemingly arbitrary numbers?Thanks, but look at the little numbers ,399 and 58
There should be a number in the box when driving. The numbers are the low and high.Thanks, but look at the little numbers ,399 and 58
It's your transmission temperature, minimum 58* maximum 399*
Thanks, didn't think of that.It's your transmission temperature, minimum 58* maximum 399*
