Laramie 4x4 V8 hemi seems to have a slight vibration when in park. Right when you switch it into drive or reverse it goes away. Anyone else experiencing this? Doesn’t seem to happen all the time either. Curious to what is causing it.
No hasn’t been cold. I live in Texas on the gulf so it’s been 50-60s here lately. Always have ran 89 octane since I drove the truck off the lot, always filling up at major brand gas stations not cheap ones (grocery stores, etc).Is it super cold where you are right now? It could be from the cold trans fluid.
You make a good point. No CEL and I don’t have an OBD reader. Guess I’ll have it looked at when I take it in to get my side mirror replaced since the folding aspect is broken.I assume no CEL. Do u have an OBD reader to see what the ignition rate is? To see if any cylinders are firing closer to an out if soec range, but not enough to trigger the CEL? Thats a good way to eliminate some things to narrow down the many causes.
You make a good point. The CEL is not on and I do not have an OBD reader.
There could also be pending codes for such things, just not ready for the engine to vonfirm and toss them on.
As odd as it may seem, I had rough idle in my new Ram after filling up recently. I had no warning lights or any indication of an issue other than the symptom itself. I found that my spring gas fill seal (there is no cap on these trucks now) was slightly open. Not sure if I pulled the fill nozzle out wrong or what. I pressed it in and quickly released it, this sealed the gap and my rough idle was gone.
I really would’ve expected an indicator light telling me something was amiss, but alas...no. If it does it again, the dealership will have to resolve for me.
Eco never comes on for me while idling as well... I have to get into a "sweet zone" of like 30-45mph until I normally see it de-active the cylinders.I have never seen my eco light come on when idling, ever. In fact, I often wonder why it cant just idle with 4 cylinders.
Wonder if MINE is the messed up one.
Hey, mine also does a slight vibration at "cold start" recently and occassionally. Im living in Florida so nothing under 40°f in morning starts. Using 93 and shutter like shake goes away after I pull off. I was suspecting it's those vibration cancelling speakers they got for the MDS. I think I've readit elsewhere on our forum. To add im still unsure what it is bc I have the etorque and it feels different and acts different in many ways than non etorque.No hasn’t been cold. I live in Texas on the gulf so it’s been 50-60s here lately. Always have ran 89 octane since I drove the truck off the lot, always filling up at major brand gas stations not cheap ones (grocery stores, etc).
