Since android auto update volume problems
LRRP71
Unless I clear the data from Android Auto app everytime I have to use it. I have no way to control radio volume by using the volume knob. Volume stays where it is when I plug the phone into the usb or gets lower. Then when I go to use maps. There are no voice directions, in maps when plugged into my 2020 ram with uconnect 4c. Waze or Google maps. No notification sounds letting me know there are text messages. Worked fine till last android auto update. using a note10+. I tried different cables, cleared the phone and U connect. reset u connect. Only clearing Android auto data before I plug in allows it to work properly. Anyone else have this happen in the last 2 weeks?
Try turning up the volume when the navigation is actively giving directions. It's the only way I have found to turn it up and down separate from the radio.
That's not the problem even the radio volume will not adjust, when I plug it in since the Google update. I know about turning the volume up or down when it starts giving directions. The problem is UNLESS I delete the data from the android auto app on my phone. Settings>apps>android auto>Storage>clear data or cache. Clearing only the cache doesn't fix it. Only clearing the data.
Everytime I plug it in. There is no way to increase or decrease the radio volume. I'm sure it has to do with the update from Google and not Uconnect, cables or USB hub. Because if I connect into my friends Ram it does the samething.
