Robert Armstrong
- Jun 22, 2019
The audible open door chime will sound any time the drivers door is opened with the ignition in accessories position. This can be annoying when you are working inside with the door open and the radio on so you can listen to the radio. It is a simple matter to trick the alarm system by making it act like the door is closed. Use the following procedure
1 - The door latch mechanism on the door looks like this photo.
2 - Push in the latch mechanism inward until it clicks.
3 - it will look like this after it clicks.
4 - Now push the mechanism inward and downward as shown until it clicks a second time.
5 - Now it will look like this - and the audible open driver door chime will be SILENT.
WARNING! WARNING! WARNING!
DON’T FORGET TO RETURN THE DOOR LATCH TO THE OPEN DOOR POSITION BEFORE CLOSING THE DOOR TO AVOID DAMAGING THE LATCH MECHANISM !
PULL THE DOOR HANDLE INSIDE THE TRUCK TO RETURN THE DOOR LATCH TO THE OPEN POSITION BEFORE CLOSING THE DOOR. FAILURE TO DO SO MAY DAMAGE THE LATCH MECHANISM.
