Lol yep. King says 1-6 months, haven’t talked to the other brands (I want Kings)
I’m very surprised that fox is taking so long.
Have you thought about rebel Bilsteins? Can’t be much longer than the standard ones
Thanks, are they Bilsteins from a Rebel? Or??Op you need a set of factory shocks for your DT if I am reading this correctly? If so I have a set that has less then 500 miles on them.
They really aren't that bad. Bridge expansion joints have some axle bounce where as Bilsteins in the past were a bit softer in the rears on my previous trucks and absorbed more of that instead of hopping on my daily commute. Hope that makes sense. Just looking for a softer ride in the rears.Curious, in what way are the shocks failing to control?
Gotcha. Have you tried adjusting your tire pressure?They really aren't that bad. Bridge expansion joints have some axle bounce where as Bilsteins in the past were a bit softer in the rears on my previous trucks and absorbed more of that instead of hopping on my daily commute. Hope that makes sense. Just looking for a softer ride in the rears.
Nah, I run about 35 in the back on Nitro's. My F150 had the same issue until I went with aftermarket and a shock that was softer and less rebound.Gotcha. Have you tried adjusting your tire pressure?
