Shifter Assembly Lights Glitching
sbdf1
Anyone else have this issue with their truck when it's cold out? Once it warms up inside the cab then it stops flashing and everything goes back to normal. No other flashing or issues on the dash, just the shifter assembly. I have a scheduled appointment at the dealer Monday and hope I can point them in the right direction.
Let me know what you find out. It was -5 the other day and mine just went totally out and I couldn't switch to 4 wheel drive...
I wonder if there is a bad/loose/corroded ground (or even power supply) for that circuit. I have heard of some loose connections at the fuse block under the hood, maybe check there?
Mine did the same thing this morning for the first time in 2 years.
Mine did the same thing this morning for the first time in 2 years. What did dealer do for you?
