RamRiderLTD
I'm buying my first RV toy hauler. It's a 2020 Forest River FSX 260RT. It's about 29" long and 4800lbs empty. I've only hauled small trailers in the past so this is new to me. I'm getting a Equalizer hitch and I was wondering how it works with the air suspension. I see videos where they measure the front and rear wheel wells to determine how the load sits the truck ,then make adjustments. The air suspension on my 19 Limited I assume will adjust itself to level when it lowers from the weight of the trailer so how can I know my WD is set up correctly? Just raising the truck to level doesn't transfer the weight back to the front axle. Should I disconnect the battery?
