Yes. It’s the front axle 4wd actuator causing the issue. Just had the exact same issue.
Part is 68399418AA. There are several threads on this. Some people fix it simply by disconnecting and reconnecting the actuator. It did nothing for me. Dealer replacement fixed the issue.
My guess is everything probably seems fine with yours but if you start trying to shift into 4wd high or 4wd auto you’ll notice that the light flashes for each one of those and never makes the actual switch. That and your traction control is likely disabled and you can’t enable it. It typically encounters a series of gremlins that are different.
Just had these three pop up while driving on the freeway. Truck has the Maximum Care Extended Warranty (Just hit 60k miles). Anyone every have all 3 of these pop up at once? Its going to the dealer once I call them on Monday. As luck has it, this happened after 5pm on a Saturday.
5thgenrams.com
The dealer will likely do some basic troubleshooting. One thing I saw as a note on the work order is they measure resistance on circuit G303 between the DTCM and actuator. It should read 3.0 ohms. Mine was reading .4 ohms so they knew it was bad. I don’t know the details on how or where to measure that circuit but if you are technically inclined maybe you could do this. That or just replace the actuator and be done with it. It’s been the reason for these 3 codes on nearly every persons truck that I’ve seen.
