Service air suspension warning
TBass
So here is what I did tonight on my 2020 Limited:
1) I disconnected my battery
2) I attached a quick connect jumper cable pigtail (https://www.amazon.com/gp/product/B01GU4O3GG/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1)
3) I connected the battery back up
4) fired up the truck & got a “Service Air Suspension“ warning light
5) I turned the truck off and then back on again and got the same warning.
6) I could still raise and lower my truck with out any issues
7) I then drove it a couple of 100 yards and the warning light went off.
8) I parked the truck, and fired up for a 4th time and no warning light came on
Has anyone experienced this when disconnecting their battery? Is this something I should worry about or make an appointment to take it in to be looked at? I’m getting ready to go cross country in 2 weeks and just don’t know how concerned I should really be.
Fatherof3
Ontario Canada
when you disconnect the battery on these trucks it causes a lot of havoc but everything usually comes back within a couple hours .
TBass
Thank you for the reply. Sure enough it looks like things sorted themselves out
Bufordw
BTW, The connector on the neg battery terminal will give you that fault if it is not connected. It is the intelligent Battery Sensor (IBS).
