Security Gateway Bypass question.
Nascar Tommy
My other Ram is a Dodge.
NW Indiana.
I need to take my 2023 Bighorn in for the trans tsb.
I've installed a Koadtech SGB harness to use with alfa obd. The installation of the bypass harness for a 64 year old was next to impossible so removing will be totally impossible!
Question is if I just hide it really good can the dealer tell there is a harness plugged into the can bus?
I don't see how with no power into it it's just dead end wiring but you never know, that's why I'm asking.
Since you used that specific harness you will probably be fine. Had you used the simpler harness they plugged into the SGW connectors, and not the terminal block, you'd definitely want to remove it or I don't think the OBD port connected to dash would work for rhem
1923bob
Poway,Ca.
I got the SGW extension from Z automotive just because this little old fat man has a hard time up under that dash if the dealership doesn't like it to bad.
