Running new speaker wire into the doors
Fartknocker
Michigan
Has anyone run new speaker wire into the front doors. I wanted to put some new component speakers in the door and use the dash location for tweeters.
After a quick look in the door jam and under the dash this seems like quite the task. If anyone has done it and could offer some tips I will shower you with praise and thanks.
KRField
Tri-Cities, TN
Not sure your trim level or features. Your through point and blockage from bod to door is the molex plug on the body in the door jamb. You may have some unused pin holes you could drill out to run wires, or pin those empty spots for the new wires.
For the dash you can wires through the access panels on the sides of the dash that pop off. You see them with the doors open.
You could run new wire to the kick panels and tap to the factory wires.
The quick and dirty option is to drill new holes gromet and loom the wires.
Depending on the power your feeding the new speakers the stock wiring may be sufficient.
