Running Board Question Urgent!!
Ram15002023
Will a short bed 2022 ram 1500 running boards fit on a 6’4 bed 2023 ram 1500? Both new bodies.
I’m about to purchase some from a man but don’t know if they’ll fit.
Rick3478
NW OH
My guess, they will probably fit but might look odd. The mounting brackets on mine all attach to the cab.
SD Rebel
San Diego, CA
The only issue is the cabs, the quad cab vs crew cab, bed length doesn't effect running boards fitment.
If the boards you are buying came off the same cab style as yours, likely crew cabs, then you are good to go.
Ram15002023
What length are wheel to wheel running boards on a 2023 Ram 1500 (new body) 6’4” bed?
Ram15002023
They are the same cab size, but they are wheel to wheel running boards so didn’t know if they’ll fit or not.
SD Rebel
San Diego, CA
Gotcha, if they mount to the cab like OEM, the mounting points should still be the same, how it looks will be entirely up to you.
BlueHemi1500
Richmond Va
I have a 2020 Lariame Crew Cab with the RAM wheel-to-wheel running boards and they end at the end of the wheel openings on my truck. I have a short 5.7 bed. Not seen a truck with the crew and longer 6.7 bed to know firsthand how the wheel-to-wheel running boards fit with the longer bed.
So, proper long bed parts, I guess would be longer. As noted above it is your opinion on how they fit and look.
Also noted if they are RAM brand, the mounting points should be bolt-on easy.
BlueHemi1500
Cbty2050
If he is close by go mock them up and see before you buy.
