laramie2019
- Dec 8, 2018
Probably comes with instructions. Please post once you get it in!I just purchased this LED light bar which is installed behind the front grid.
I will have to remove the front grill assembly in order to install it.
Has anyone attempted this yet?
That's interesting @geotex1 . My longhorn (build date May 2018) is a two piece design and I bought a replacement mesh grill to do some cutting for a light bar. I wonder what the parts guy would see if he looked up the part #?
https://www.mymoparparts.com/oem-parts/mopar-grille-lower-68274572aa
I bought the same light, went to install it and discovered my front mesh grille is one solid piece. Called rough country and they didn’t have a clue about it. Be interested to see what other Gen5 owners do? Oh well maybe install it on my Polaris!Looks like FCA made a design change.
On my Laramie, specs below and built the ens of October 2018, the insert is in fact a single piece. No front mesh with solid rear panel as others have and RC assumed. I'm going to mock up the kit on mine to see if there's enough adjustability to bring the light out flush to the face of the insert, if so i will cut an opening. If not, I'll have the Christmas gift returned and look to fabricate something of better design.
I have notified RC with pictures.
My local dealer is open today, and I chatted with the parts guy for 20min. He went through all truck levels with the sensors, and found none in the parts database as two-piece.
So if you watch the video on their site for these, there are also some lights in the main grill. Does anyone know anything about these?Had mine put on about a week ago. Looks great and had the switch mounted under the steering wheel. Also purchased the 6” lights for the grille as pictured on Rough Country but apparently the brackets haven’t been made yet to fit the truck from Rough Country. RC said they should be coming soon??
Thanks! I will be watching for those.Yes, I bought those lights as well; however, I was told that they couldn’t be mounted very cheap at all because RC does not have the brackets that fit the truck yet. The place that mounted my light bar told me it would be in my best wallet interest to wait until they come out before installing them.
None at allHave you notice any whistling or wind noise with the light bar?
Awesome!Received an email from Rough Country 1-18-19 indicating that the kit will become available "within a week or so".
