Not sure if this site has been posted before but I found this during my brain melting search for info on what wheel and tire combo will fit on my 2019 Ram 1500 Sport. Input your stock wheel and tire size and then the sizes you want to change to and it will illustrate and describe in detail things like clearances from suspension parts and fenders. Tip-Use the drop down menu where it says ISO Metric to change to LT High Flotation to enter tire size in inches. ie. 35 x 12.50. Hope this helps someone else.
Rim & Tire Size Calculator. Custom Offsets
Tire Tech Information - The Wheel Fitment, Tyre Stretch, Rolling Radius and Speedometer Error Calculator. Play with specs, try different settings, compare results
www.wheel-size.com
