Right turn signal stuck
judiths05
my right turn signal came on out of nowhere, the only way to shut it off was to move the switch to the left position which turned off the blinking signal but now I don’t have a left turn signal. When it returns to neutral the right signal blinks, when I turn on the right turn signal the right signal blinks correctly. It went away after a few days and everything worked fine for months until again driving down the interstate started happening again this time lasting for weeks. I constantly have to drive around with the left blinker on to keep right side from blinking however when I turn and goes back to neutral the right side starts to go off again and I have to turn on the left signal to stop it… really annoying!!! I have a 2020 ram 1500 bighorn I saw someone else had the same issue but didn’t post anything after on if they found a fix anyone had the same issue or know the fix ?
dajogejr
Probably have to replace the stalk.
There was a recall for 2019 I think…. I don’t it involved 2020.
  • Jako
