runamuck
- Nov 29, 2018
Does the Hellwig rear bar make much difference in handling feel? Would it restrict wheel travel if offroad from stock? Does it make curves feel flat for body roll? Thanks
it is stiffer than stock and reduces lean on turns. I put one on to add a little stiffness to the rear and to reduce a little bit of shimmy I was getting while towing. the sway bar is the same size as the oem one so should not make any difference on wheel travel except that there are three optional positions for the link connection. I have mine connected to the center one which potentially could reduce overall travel by as much as an inch but I think you would get the same amount of travel just would compress the spring more to do it, thereby resisting lean when turning. the oem sway bar is hollow and pretty light while the after market ones are solid steel and stiffer and are a little heavier. I can feel the improvement . an easy DIY project taking maybe 30 mins. to do.
