UltraMadMax
- Jun 2, 2018
Today after washing my truck, I embarked on the journey of installing the Lomax Cover and the bed divider by Mopar. I decided to provide a review.
I had to install the rails for the Lomax first and they went on easily. I then needed to install the Mopar Bed Divider and found that this was much more complicated. It came with its own rails which make the current bed rail system crowded. It barely fits under the Lomax Cover but it fits. I then easily placed the Lomax cover on and it is great.
The Lomax design and build quality is top notch. I am very pleased with how easily it goes on and comes off and folds. Since it is made out of aluminum, it is strong and light.
The Mopar Divider is made out of plastic and its design is flawed. I was barely able to get it into its first locked position and am unable to move it. the release levers do not pull back far enough to release from their notches which is how it is supposed to work. This means, I am unable to move its location in the bed. The plastic seems like it will easily break. If I would have known this before purchasing it, I would have passed. I would not recommend this divider and wait for an aftermarket divider to become available. I will leave it in for now until I find something better.
Update: After much time has passed, I finally was able to get the defective divider replaced at the dealer and the new one works. I can now use it in my bed and it is better than nothing. Hopefully someone comes up with a better design that does not require additional side rails.
