Is there any correlation between the oil temp and the heat needed to REGEN? I don't have the tools to read if the truck is passively REGENING, but when I tow, the oil temp is around 225 to 232.
I haven't noticed more than a degree or two change in oil or coolant temp during regens (monitored using Torque app). The best way I have noticed regens, if not monitoring EGTs/DPF load is a drop in the MPGs as the engine dumps more diesel into the filter to light it up.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
