Just got them in July and I Live in NC, so I have no clue.How are these in snow?
You truck looks great and those tires definitely are a huge improvement over the looks of the street looking tires that come on stock! I also have a Limited with the Night package and your truck has made up my mind to go with these tires! Did you install the leveling kit prior to the tires or after? Just wondering if there were rubbing issues which prompted the leveling? Planning on leveling mine but was not sure if I was going to do it prior to or after tires.I had mine installed with the 2nd version out and I love it.
View attachment 136598 View attachment 136599
Thanks!You truck looks great and those tires definitely are a huge improvement over the looks of the street looking tires that come on stock! I also have a Limited with the Night package and your truck has made up my mind to go with these tires! Did you install the leveling kit prior to the tires or after? Just wondering if there were rubbing issues which prompted the leveling? Planning on leveling mine but was not sure if I was going to do it prior to or after tires.
Thanks,
Jim
I just installed the LT275/55/20 on my truck and curious to see what pressure you guys are running?
Tires show max PSI of 80, installer set them to 40PSI thinking the max was 50PSI.
For everyday driving town/highway (not towing) should it be closer to 50-60 PSI?
Great.When I had Nittos, I emailed them picture of my load sticker (from the driver door jamb), told them which tires I bought, and they replied with a recommended pressure.
Looks like they’ve got a contact form now. Select “Tire Warranty & Owners Support” for Reason, then PSI Inquiry for Regarding.Great.
I will do that
Thanks
thanks.Looks like they’ve got a contact form now. Select “Tire Warranty & Owners Support” for Reason, then PSI Inquiry for Regarding.
