Recalibrating speedometer
smkt404
When replacing 20 inch wheels 275 55 R20 with 285 45 R22 do you need to Recalibate?
DEG
I wouldn't worry about it with that very minor change in diameter. The change in height is only about 2/10s of an inch. At 70 mph your actual speed with be 70.4 mph.
According to my tire size calculator the 275-55-20 are 31.9 inches diameter. The 285-45-22 are 32.1 in diameter.
Darksteel165
Massachusetts
This is also assuming it was correct from the factory which I don't think all of them are. Mine was off from the factory with oem 22s.
Jedi9
At that difference I wouldn't bother. Tires usually read smaller dia after being loaded. Best way to check run a speedometer app and see what the difference is from your speedometer.
Machinetools1
Coalinga Ca
Has anyone used a Hypertech In-Line Speedometer Calibrator (19-22 RAM 1500). I was planning on purchasing one and installing put wanted to know if anyone has used one yet?
awesomedudekj
Iowa
I think you'll find that most people use alfaobd, jscan, or tazer. You'll be able to make the tire size adjustment and much more, plus I think you'll end up spending less.
Machinetools1
Coalinga Ca
Thanks for the input, Glad I asked as I guess the Hypertech In-Line Speedometer Calibrator (19-22 RAM 1500) is not California legal. Thanks again.
