Recalibrate Blend Door Actuators
swarggs
Pennsylvania
I’m looking for advice on the best way to handle HVAC blend door actuator calibration.
What are my options? Is this something that’s easiest to have done at the dealer, or is there a scan tool or other equipment I can buy to perform the calibration myself? If I do end up buying a scan tool, I’d like it to be something that would also be useful for other diagnostics and maintenance tasks down the road.
Background:
I recently replaced the heater core on my 2019 Ram 1500 with dual-zone climate control (it’s out of warranty). I followed the Alldata procedure closely, but after putting everything back together, the blend doors don’t seem to be working correctly. When I select defrost mode, air seems to be directed towards the correct part of the dash, but the defrost doors closes instead of opening. Hot and cold settings work as designed.
Alldata mentioned performing a calibration after reinstalling the dash, so I’m assuming that step might resolve the HVAC issues. Given that, would taking it to the dealer be the simplest solution, or is there a practical DIY option?
Side note: For anyone else tackling a heater core replacement, I was able to leave the coolant lines connected and slightly rotate the HVAC enclosure just enough to remove and reinstall the heater core. It saved several extra steps and avoided the added hassle of refrigerant recovery, which no dealer or shop was willing to handle for me.
That is good to know.
I skimmed thru the heater core replacement procedure and did not see anything about having to run a calibration.
Only after actuator replacement and getting codes?
What DTC are you getting?
I have AlfaOBD and OBDLink MX Plus, the combination has worked great for the troubleshooting and live data monitoring that I have done.
Not sure if Alfa can do a blend door calibration how ever.
I'd think a system like this would overdrive the actuator one direction or the other for a period of time that is longer than the actuator is supposed to run.
Example, a 30 second actuator would be driven for 60 seconds. Thereby resetting zero every startup or shutdown
I ended up using AlfaOBD to run some HVAC mode door tests. I received 2 fault codes:
B11C2 - Front Mode Door 1 Control: Performance or incorrect operation.
B11C3 - Front Mode Door 1 Travel Range Too Small.
I can hear the front mode door trying to actuate. I suppose the door itself may be damaged / blocked or the door is in the wrong position and needs calibrating.
Did you look up the B-codes in Alldata, there is a comprehensive troubleshooting/diagnosis instructions listed.
I was unaware that Alldata included that. I only subscribed for 1 month while I was performing the repair. I'll look into that and see if I can hunt down the problem, thank you.
