An interesting turned up as I've grappled with understanding different tires, level/lift kit/long arm kit, and air suspension settings: There are no specs for the 2019 Rebel. Anywhere that I've looked anyway.
Where have I looked? The brochure, the Press Release Specs, the Owner's Manual, this forum, the Ram forum, etc. I became particularly interested when looking at "Level Kits" for the air suspension.
And it started by looking for wheel travel...a pretty key part of suspension design.
I have ended up back in 2015, when data was published. Rams came with 265/70-17 (31.7" tall) or 275/60-20 (33.2" tall). The Rebel had 285/70-17 (32.8" tall, note: not the tallest). All Rebels had air suspension then.
The height of the roof is pretty immutable, so let's look at that:
Adjusted for the tire sizes, what is that?
It seems the Rebel was lifted 1/2 inch. Which should be the same now. It also seems that the max lift on the Rebel was less than a non-Rebel with the air suspension. This is a simple computer or link adjustment. Based on the tailgate the ground measurement, it appears that in 2015 Rebel more of the lift was in the front.
Now the Rebel has steel springs. How did they raise it 1/2"? By raising the lower spring perch and a stiffer or longer spring in the back? Did they raise the back or just partially level the front? Did the Bilstein have more travel available, or was it done at the expense of droop travel?
How do they do it on the Off-Road Group that claims the same 1" lift but has the original 275/60-18 or 275/60-20 tire sizes?
What is the wheel travel with steel springs? What is with the air suspension? What is it with the normal or off-road suspensions?
Or better: Why doesn't FCA publish the info?
Tire | Entry / Exit | Normal Ride Height | Off Road 1 | Off Road 2/Off Road |
265/70-17 | 75.2 (1,909.0) | 77.2 (1,962.0) | 78.2 (1,986.6) | 79.2 (2,013.0) |
275/60-20 | 75.8 (1,924.4) | 77.8 (1,977.4) | 78.8 (2,002.0) | 79.9 (2,028.4) |
285/70-18 | 75.3 (1,913.7) | 78.1 (1,984.6) | 79.1 (2,010.2) |
Tire Diameter | Delta | Entry / Exit | Normal Ride Height | Off Road 1/Off Road | Off Road 2 |
31.7 | 0 | 75.2 | 77.2 | 78.2 | 79.2 |
33.2 | 0.75 | 75.05 | 77.05 | 78.05 | 79.15 |
32.8 | 0.55 | 74.75 | 77.55 | 78.55 |
