Looking to find the height to the flares on a stock Rebel.
Curious as to how much taller I am currently with my new suspension and tires.
Forgot to record what I was at before.
A stock offroad package ram/Rebel has about 22"-22.5" from center of wheel hub to bottom of fender on the front end. Those are the two best points of measurement since tire size or even psi can make a difference. Typically the driver side tends to be heavier so the measurement may differ on both sides.
From ground to fender before my spacers on stock tires I was 37.5 in front and 39.5/40.25 in the rear (driver being lower). I put in 2" spacers in the front, 1/2" spacer on driver side, and Timber Grove airbags. Now it sits at 39.5 front, 40.5 rear on stock tires.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
