Rebel + Mopar UCAs/5100s/Motofab 2”
Nsm42
Hi everyone,
I have a 2020 Rebel 5.7 that I’m looking to do a mild lift on. Would the combination of the Mopar UCAs, Motofab 2” level, plus 5100s be a likely compatible setup? I’ve read that the Mopar UCAs (from their lift kit) offer a bit more ball joint movement and hope that this would be a decent setup for my DD for light off roading without too much stress on other suspension components. Thanks in advanced!
CJR28
You dont need the motofab 2” spacer and the 5100s, its either one or the other. 5100s will be the better option of the two
Nsm42
Great to hear, thank you for that. Would the spacers just add unnecessary stress on the suspension if I were looking for a bit of extra lift over the 5100s?
LaxDfns15
Memphis, TN
If you're lifting with both the 5100's and spacers you're going to run into CV axle issues because of the angles. The Mopar UCA's aren't really meant to handle anything over 2" as well.
NewLove
Don’t even think you need the UCA’s...
