Rebel bumper skid plate on non rebel?
osage91
Does anybody know if the metal front bumper skid plate on the rebel will fit over the front bumper of other ram 1500 models without major modifications?
I like your thinking . . . I've wondered this too, but in regards to a Quad Big Horn or Laramie With the ORP ! I have not taken a look under either a Rebel or ORP'd RAM to Compare ! Hint hint . I also at some point will be doing just this AND inquiring at the Parts Department AND a chat or 2 with a Service Manager AND his recommended Mechanic in the shop ! The Parts guys have good computer access for 3d schematics . Just thought of something -- at YouTube's MIKES-CAR-INFO All of his videos start out with an under carriage slow-mo rear to front . He may have a Rebel & a RAM w/ORP ? ? ? If not keep checking back as the Dealership he uses for FCA stuff will be getting lots more 2020's as the weeks roll on !
I know this is really old, but does anyone have an answer to the Rebel front skid plate fitting on a Laramie? Just curious...thank you!
Not sure if it’ll fit, but I just removed my bumper. Here’s what the back side looks like if you want to compare.
Still no answer? I was wondering about this just today when I saw that you can buy the skid plate new for 275$ (W/discount) from Mopar.
no you can not ... you would need to replace headlights/ bottom fins and then maybe it works
reason i know is because i installed a non rebel bumper and it didnt work well had alot of modifications
i had to change mounting points about 1 3/4 of inch higher to raise and cover the gaps
so based off that i think you gonna need to lower the rebels mounting points by similar lenghts
the fins under headlight on rebel are about 5 inchs
on other non rebels its about 7 inchs
