Yes it would. I have a Laramie and installed Rebel rear shocks. Be advised my Laramie has the ORG as well. The ORG shocks where also a little bit longer than the Bilstein but still works fine. As far as telling a difference between ORG shocks vs Rebel..... hmmmm nope.
Also note that the Rebel shocks where a little bit harder to push down by hand vs the ORG shocks.
Do you have part #'s?
Interesting... I have a 2019 Laramie Crew Cab as well.. regular, non ORG or non off road package...
Looking for cheaper alternative than the mopar fox shocks and considering Bilstien has yet to release 5100 series.
Questions:
1. the 68313613AC rebel rear shocks will fit. Will I also need the ORG rear coil springs?
2. What about the front shocks, any part number? Like to have the same 1"+ inch as the rebel has.
I do not want to use spacer/level kit. Rather do suspension so the geometry is correct. Wanting to be able to install 295/60r20's and not rub.
The Rebel rear shocks installed on my Ram 1500 wORG
The shocks do not add any lift. Ride height is determined only by the springs in the rear.nice! Do you have a picture of the trucks stance as it stands? Would think it would have more forward rake with those rear shocks? as I believe those rebel shocks add 1"+ lift....
